Numerical study of acoustic multiperforated plates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2012
It is rather classical to model multiperforated plates by approximate impedance boundary conditions. In this article we would like to compare an instance of such boundary conditions obtained through a matched asymptotic expansions technique to direct numerical computations based on a boundary element formulation in the case of linear acoustic.
multiperf_acoust.pdf (818.43 Ko) Télécharger le fichier
hal-00686434 , version 1 (10-04-2012)
Abderrahmane Bendali, M'Barek Fares, Sophie Laurens, Sébastien Tordeux. Numerical study of acoustic multiperforated plates. ESAIM: Proceedings, 2012, 37, pp.166-177. ⟨10.1051/proc/201237005⟩. ⟨hal-00686434⟩
198 Consultations
209 Téléchargements
