Lower and upper bounds for the Rayleigh conductivity of a perforated plate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2013
Lower and upper bounds for the Rayleigh conductivity of a perforation in a thick plate are usually derived from intuitive approximations and by physical reasoning. This paper addresses a mathematical justification of these approaches. As a byproduct of the rigorous handling of these issues, some improvements to previous bounds for axisymmetric holes are given as well as new estimates for inclined perforations. The main techniques are a proper use of the variational principles of Dirichlet and Kelvin in the context of Beppo-Levi spaces. The derivations are validated by numerical experiments in the two-dimensional axisymmetric case and the full three-dimensional one.
publi-rayleigh.pdf (934.99 Ko) Télécharger le fichier
hal-00686438 , version 1 (10-04-2012)
Sophie Laurens, Sébastien Tordeux, Abderrahmane Bendali, M'Barek Fares, P. Robert Kotiuga. Lower and upper bounds for the Rayleigh conductivity of a perforated plate. ESAIM: Mathematical Modelling and Numerical Analysis, 2013, 47 (6), pp.1691-1712. ⟨10.1051/m2an/2013082⟩. ⟨hal-00686438⟩
335 Consultations
285 Téléchargements
