Universally Composable Key-Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Robert Kunnemann
  • Fonction : Auteur
  • PersonId : 923631
Graham Steel
  • Fonction : Auteur
  • PersonId : 923660
We present the first key-management functionality in the Universal Composability (UC) framework. It allows the enforcement of a wide range of security policies and can be extended by diverse key usage operations with no need to repeat the security proof. We illustrate its use by proving an implementation of a Security API secure with respect to arbitrary key-usage operations and explore a proof technique that allows the storage of cryptographic keys externally, a novel development in the UC framework.
uc_keymanagement.pdf (621.05 Ko) Télécharger le fichier
hal-00686535 , version 1 (10-04-2012)
  • HAL Id : hal-00686535 , version 1
Steve Kremer, Robert Kunnemann, Graham Steel. Universally Composable Key-Management. 2012. ⟨hal-00686535⟩
160 Consultations
226 Téléchargements
