Temporal Localization of Actions with Actoms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We address the problem of detecting actions, such as drinking or opening a door, in hours of challenging video data. We propose a model based on a sequence of atomic action units, termed "actoms", that are semantically meaningful and characteristic for the action. Our Actom Sequence Model (ASM) represents the temporal structure of actions as a sequence of histograms of actom-anchored visual features. Our representation, which can be seen as a temporally structured extension of the bag-of-features, is flexible, sparse, and discriminative. Training requires the annotation of actoms for action examples. At test time, actoms are detected automatically based on a non-parametric model of the distribution of actoms, which also acts as a prior on an action's temporal structure. We present experimental results on two recent benchmarks for temporal action detection: "Coffee and Cigarettes" and the "DLSB" dataset. We also adapt our approach to a classification by detection set-up and demonstrate its applicability on the challenging "Hollywood 2" dataset. We show that our ASM method outperforms the current state of the art in temporal action detection, as well as baselines that detect actions with a sliding window method combined with bag-of-features.
Cet article s'intéresse au problème de la détection temporelle d'actions, comme "ouvrir une porte", dans des bases de données contenant des heures de vidéo. Nous proposons un modèle basé sur des suites d'actions atomiques, appelées "actoms". Ces actoms sont des sous-événements interprétables qui caractérisent l'action à modéliser. Notre modèle, nommé "Actom Sequence Model" (ASM), décrit la structure temporelle d'une action par le biais d'une suite d'histogrammes de descripteurs locaux localisés temporellement. Cette représentation est une extension flexible, parcimonieuse, discriminative et structurée du populaire "sac de mots visuels". La période d'apprentissage nécessite l'annotation manuelle d'actoms, sans que cela ne soit requis à l'étape de détection. En effet, les actoms de nouvelles vidéos sont automatiquement détectés à l'aide d'un modèle non-paramétrique de la structure temporelle d'une action, estimé à partir des exemples d'apprentissage. Nous présentons des résultats expérimentaux sur deux bases de données récentes pour la détection temporelle d'actions: "Coffee and Cigarettes" et "DLSBP". De plus, nous adaptons notre approche au problème de classification par détection et démontrons ses performances sur la base "Hollywood 2". Nos résultats montrent que l'utilisation d'ASM améliore les performances par rapport à l'état de l'art et par rapport à l'approche par fenêtre glissante avec sac de mots, couramment utilisée en détection.
RR-7930.pdf (1.17 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
Format : Figure, Image
hal-00687312 , version 1 (12-04-2012)
hal-00687312 , version 2 (21-01-2013)
  • HAL Id : hal-00687312 , version 2
Adrien Gaidon, Zaid Harchaoui, Cordelia Schmid. Temporal Localization of Actions with Actoms. [Research Report] RR-7930, INRIA. 2012. ⟨hal-00687312v2⟩
737 Consultations
872 Téléchargements
