First steps on asynchronous lattice-gas models with an application to a swarming rule - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nazim Fatès
Vincent Chevrier
Lattice-gas cellular automata are often considered as a particular case of cellular automata in which additional constraints apply, such as conservation or spatial exclusion of particles. But what about their updating? How to deal with non-perfect synchrony? Novel definitions of asynchronism are proposed that respect the specificity of lattice-gas models. These definitions are then applied to a well-known swarming rule in order to explore the robustness of the model to perturbations of its updating.
boure2012-HAL.pdf (397.15 Ko) Télécharger le fichier
hal-00687987 , version 1 (16-04-2012)
hal-00687987 , version 2 (14-06-2012)
Olivier Bouré, Nazim Fatès, Vincent Chevrier. First steps on asynchronous lattice-gas models with an application to a swarming rule. 10th International Conference on Cellular Automata for Research and Industry, Sep 2012, Fira, Greece. pp.633-642, ⟨10.1007/978-3-642-33350-7_65⟩. ⟨hal-00687987v2⟩
332 Consultations
260 Téléchargements
