T-coercivity and continuous Galerkin methods: application to transmission problems with sign changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
To solve variational indefinite problems, one uses classically the Banach-Necas-Babuška theory. Here, we study an alternate theory to solve those problems: T-coercivity. Moreover, we prove that one can use this theory to solve the approximate problems, which provides an alternative to the celebrated Fortin lemma. We apply this theory to solve the indefinite problem $div\sigma\nabla u = f$ set in $H^1_0$, with $\sigma$ exhibiting a sign change.
ChCi11a.pdf (670.38 Ko) Télécharger le fichier
hal-00688862 , version 1 (18-04-2012)
  • HAL Id : hal-00688862 , version 1
Lucas Chesnel, Patrick Ciarlet. T-coercivity and continuous Galerkin methods: application to transmission problems with sign changing coefficients. 2012. ⟨hal-00688862⟩
362 Consultations
414 Téléchargements
