CoCoNutTrix: Collaborative Retrofitting for Information Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Computer Graphics and Applications Année : 2009
Petra Isenberg
Anastasia Bezerianos
Nathalie Henry
  • Fonction : Auteur
  • PersonId : 924125
Sheelagh Carpendale
  • Fonction : Auteur
  • PersonId : 924126
Jean-Daniel Fekete
Most information visualization systems incorporate little or no specific support for collaboration. Yet, collaboration has been identified as a means to deal with the increasing amount and complexity of information available to analysts. Re-implementing existing applications to fully incorporate our current understanding of computer supported cooperative work could be exhaustive, time consuming, and expensive. As a first step, we explored how a co-located collaborative information visualization and analysis environment can be created in a cost-effective manner. We retrofitted NodeTrix, a social network analysis tool, by extending it to enable multi-user interaction in collaborative environments. We present details of the retrofitting process and results of a user study assessing the usability of our retrofitted system. Our results support the effectiveness of our low-cost collaborative retrofitting for collaborative network analysis and highlight implications for practitioners.
coconutrix-published_1.4.pdf (2.79 Mo) Télécharger le fichier
Format : Figure, Image
hal-00690020 , version 1 (20-04-2012)
Petra Isenberg, Anastasia Bezerianos, Nathalie Henry, Sheelagh Carpendale, Jean-Daniel Fekete. CoCoNutTrix: Collaborative Retrofitting for Information Visualization. IEEE Computer Graphics and Applications, 2009, Special Issue on Collaborative Visualization, 29 (5), pp.44--57. ⟨10.1109/MCG.2009.78⟩. ⟨hal-00690020⟩
234 Consultations
528 Téléchargements
