Learning Rational Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rational functions are transformations from words to words that can be defined by string transducers. Rational functions are also captured by deterministic string transducers with lookahead. We show for the first time that the class of rational functions can be learned in the limit with polynomial time and data, when represented by string transducers with lookahead in the diagonal-minimal normal form that we introduce.
0.pdf (426.59 Ko) Télécharger le fichier
hal-00692341 , version 1 (29-05-2012)
  • HAL Id : hal-00692341 , version 1
Adrien Boiret, Aurélien Lemay, Joachim Niehren. Learning Rational Functions. 16th International Conference on Developments of Language Theory, Apr 2012, Taipee, Taiwan. ⟨hal-00692341⟩
155 Consultations
327 Téléchargements
