Color Lens: Adaptive Color Scale Optimization for Visual Exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2011
Visualization applications routinely map quantitative attributes to color using color scales. Although color is an effective visualization channel, it is limited by both display hardware and the human visual system. We propose a new interaction technique that overcomes these limitations by dynamically optimizing color scales based on a set of sampling lenses. The technique inspects the lens contents in data space, optimizes the initial color scale, and then renders the contents of the lens to the screen using the modified color scale. We present two prototype implementations of this pipeline and describe several case studies involving both information visualization and image inspection applications. We validate our approach with two mutually linked and complementary user studies comparing the Color Lens with explicit contrast control for visual search.
colorlens-journal_1_.pdf (4.48 Mo) Télécharger le fichier
Format : Figure, Image
hal-00694430 , version 1 (28-05-2012)
Niklas Elmqvist, Pierre Dragicevic, Jean-Daniel Fekete. Color Lens: Adaptive Color Scale Optimization for Visual Exploration. IEEE Transactions on Visualization and Computer Graphics, 2011, pp.795--807. ⟨10.1109/TVCG.2010.94⟩. ⟨hal-00694430⟩
152 Consultations
403 Téléchargements
