ANALYSIS OF SST IMAGES BY WEIGHTED ENSEMBLE TRANSFORM KALMAN FILTER - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a novel, efficient scheme for the analysis of Sea Surface Temperature (SST) ocean images. We consider the estimation of the velocity fields and vorticity values from a sequence of oceanic images. The contribution of this paper lies in proposing a novel, robust and simple approach based onWeighted Ensemble Transform Kalman filter (WETKF) data assimilation technique for the analysis of real SST images, that may contain coast regions or large areas of missing data due to the cloud cover.
Analysis_of_SST_Images_by_Weighted_Ensemble_Transform_Kalman_Filter.pdf (502.5 Ko) Télécharger le fichier
hal-00694594 , version 1 (04-05-2012)
  • HAL Id : hal-00694594 , version 1
Gorthi Sai, Sébastien Beyou, Etienne Mémin. ANALYSIS OF SST IMAGES BY WEIGHTED ENSEMBLE TRANSFORM KALMAN FILTER. Geoscience and Remote Sensing Symposium (IGARSS), Jul 2011, Vancouver,BC, Canada. ⟨hal-00694594⟩
142 Consultations
317 Téléchargements
