Energy Management in IaaS Clouds: A Holistic Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Energy efficiency has now become one of the major design constraints for current and future cloud data center operators. One way to conserve energy is to transition idle servers into a lower power-state (e.g. suspend). Therefore, virtual machine (VM) placement and dynamic VM scheduling algorithms are proposed to facilitate the creation of idle times. However, these algorithms are rarely integrated in a holistic approach and experimentally evaluated in a realistic environment. In this paper we present the energy management algorithms and mechanisms of a novel holistic energy-aware VM management framework for private clouds called Snooze. We conduct an extensive evaluation of the energy and performance implications of our system on 34 power-metered machines of the Grid'5000 experimentation testbed under dynamic web workloads. The results show that the energy saving mechanisms allow Snooze to dynamically scale data center energy consumption proportionally to the load, thus achieving substantial energy savings with only limited impact on application performance.
efeller.pdf (226.16 Ko) Télécharger le fichier
hal-00695038 , version 1 (20-07-2012)
  • HAL Id : hal-00695038 , version 1
Eugen Feller, Cyril Rohr, David Margery, Christine Morin. Energy Management in IaaS Clouds: A Holistic Approach. 5th IEEE International Conference on Cloud Computing (CLOUD), Jun 2012, Honolulu, Hawaii, United States. ⟨hal-00695038⟩
369 Consultations
435 Téléchargements
