Rephrasing interoperability in terms of connector behaviours - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We supply details of a compositional specification theory we have been working on for modelling connectors and components. This supports the operations of parallel composition, for examining the structural behaviour of networked systems, logical conjunction, for supporting independent development of components, and quotient for incremental development in the form of component/connector synthesis. Our framework, a portion of which is conceptually similar to interface automata, is unique in that we've provided the first definition of quotient that can act on components exhibiting non-determinism, as well as the first definition of conjunction on this flavour of model. A refinement preorder corresponding to safe-substitutivity allows for the seamless interchanging of components and connectors without violating environmental assumptions. Our formulation of refinement also ensures that the framework enjoys strong algebraic properties. These are necessary for reasoning about components and connectors in a compositional manner.
CONNECT_deliverable_D2_3.pdf (931.47 Ko) Télécharger le fichier
hal-00695583 , version 1 (09-05-2012)
  • HAL Id : hal-00695583 , version 1
Marco Autili, Taolue Chen, Chris Chilton, Tingting Han, Lukas Holik, et al.. Rephrasing interoperability in terms of connector behaviours. [Research Report] 2012. ⟨hal-00695583⟩
Collections
CONNECT LARA
132 Consultations
154 Téléchargements
