Mélange: Space Folding for Visual Exploration
Navigating in large geometric spaces--such as maps, social networks, or long documents--typically requires a sequence of pan and zoom actions. However, this strategy is often ineffective and cumbersome, especially when trying to study and compare several distant objects. We propose a new distortion technique that folds the intervening space to guarantee visibility of multiple focus regions. The folds themselves show contextual information and support unfolding and paging interactions. We conducted a study comparing the space-folding technique to existing approaches and found that participants performed significantly better with the new technique. We also describe how to implement this distortion technique and give an in-depth case study on how to apply it to the visualization of large-scale 1D time-series data.
Interface homme-machine [cs.HC]
melange-journal.pdf (5.87 Mo)
Télécharger le fichier
Format : Figure, Image
