Approximate Modified Policy Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Bruno Scherrer
Victor Gabillon
  • Fonction : Auteur
  • PersonId : 925091
Mohammad Ghavamzadeh
  • Fonction : Auteur
  • PersonId : 868946
Modified policy iteration (MPI) is a dynamic programming (DP) algorithm that contains the two celebrated policy and value iteration methods. Despite its generality, MPI has not been thoroughly studied, especially its approximation form which is used when the state and/or action spaces are large or infinite. In this paper, we propose three implementations of approximate MPI (AMPI) that are extensions of well-known approximate DP algorithms: fitted-value iteration, fitted-Q iteration, and classification-based policy iteration. We provide error propagation analyses that unify those for approximate policy and value iteration. On the last classification-based implementation, we develop a finite-sample analysis that shows that MPI's main parameter allows to control the balance between the estimation error of the classifier and the overall value function approximation.
article.pdf (493.76 Ko) Télécharger le fichier
hal-00697169 , version 1 (14-05-2012)
hal-00697169 , version 2 (16-05-2012)
Bruno Scherrer, Victor Gabillon, Mohammad Ghavamzadeh, Matthieu Geist. Approximate Modified Policy Iteration. [Research Report] 2012. ⟨hal-00697169v2⟩
378 Consultations
260 Téléchargements
