Classical call-by-need sequent calculi : The unity of semantic artifacts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We systematically derive a classical call-by-need sequent calculus, which does not require an unbounded search for the standard redex, by using the unity of semantic artifacts proposed by Danvy et al. The calculus serves as an intermediate step toward the generation of an environment-based abstract machine. The resulting abstract machine is context-free, so that each step is parametric in all but one component. The context-free machine elegantly leads to an environment-based CPS transformation. This transformation is observationally different from a natural classical extension of the transformation of Okasaki et al., due to duplication of un-evaluated bindings.
classical-need-artifacts.pdf (323.74 Ko) Télécharger le fichier
hal-00697241 , version 1 (15-05-2012)
Zena Ariola, Paul Downen, Hugo Herbelin, Keiko Nakata, Alexis Saurin. Classical call-by-need sequent calculi : The unity of semantic artifacts. FLOPS 2012 - 11th International Symposium on Functional and Logic Programming, May 2012, Kobe, Japan. pp.32-46, ⟨10.1007/978-3-642-29822-6⟩. ⟨hal-00697241⟩
104 Consultations
170 Téléchargements
