Non-D-finite excursions in the quarter plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Combinatorial Theory, Series A Année : 2014
We prove that the sequence $(e^{\mathfrak{S}}_n)_{n\geq 0}$ of excursions in the quarter plane corresponding to a nonsingular step set~$\mathfrak{S} \subseteq \{0,\pm 1 \}^2$ with infinite group does not satisfy any nontrivial linear recurrence with polynomial coefficients. Accordingly, in those cases, the trivariate generating function of the numbers of walks with given length and prescribed ending point is not D-finite. Moreover, we display the asymptotics of $e^{\mathfrak{S}}_n$.
BoRaSa12.pdf (596.43 Ko) Télécharger le fichier
hal-00697386 , version 1 (15-05-2012)
hal-00697386 , version 2 (05-12-2013)
Alin Bostan, Kilian Raschel, Bruno Salvy. Non-D-finite excursions in the quarter plane. Journal of Combinatorial Theory, Series A, 2014, 121, pp.45-63. ⟨10.1016/j.jcta.2013.09.005⟩. ⟨hal-00697386v2⟩
483 Consultations
349 Téléchargements
