A Sketch-Based Interface for Annotation of 3D Brain Vascular Reconstructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Within the medical imaging community, 3D models of anatomical structures are now widely used in order to establish more accurate diagnoses than those based on 2D images. Many research works focus on an automatic process to build such 3D models. However automatic reconstruction induces many artifacts if the anatomical structure exhibits tortuous and thin parts (such as vascular networks) and the correction of these artifacts involves 3D-modeling skills and times that radiologists do not have. This article presents a semi-automatic approach to build a correct topology of vascular networks from 3D medical images. The user interface is based on sketching; user strokes both defines a command and the part of geometry where the command is applied to. Moreover the user-gesture speed is taken into account to adjust the command: a slow and precise gesture will correct a local part of the topology while a fast gesture will correct a larger part of the topology. Our system relies on an automatic segmentation that provides a initial guess that the user can interactively modify using the proposed set of commands. This allows to correct the anatomical aberrations or ambiguities that appear on the segmented model in a few strokes.
Dans le domaine de l'imagerie médicale, la modélisation 3D de structures anatomiques est maintenant largement utilisée dans l'optique d'é}tablir des diagnostics plus précis qu'avec des données basées sur des images 2D. Aujourd'hui, de nombreux travaux mettent l'accent sur les méthodes automatique de reconstruction de modèles 3D mais ces méthodes induisent de nombreuses erreurs. Avec une structure anatomique (réseau cérébral) présente des parties assez fines et tortueuses, des erreurs sont introduites, cela nécessitent de la correction du modèle 3D, mais aussi des compétences et des heures que les radiologistes ne possèdent pas. Cet article présente une approche semi-automatique de reconstruction d'une topologie correcte de réseaux vasculaires issus d'images médicales en 3D. Notre système repose sur une segmentation automatique qui fournit une estimation initiale dont l'utilisateur peut modifier interactivement en utilisant un jeu proposé de commandes basées sur le croquis. Cela permet de corriger les aberrations anatomiques ou les ambiguïtés qui apparaissent sur le modèle segmenté en quelques traits.
RR-7954.pdf (2.48 Mo) Télécharger le fichier
hal-00698832 , version 1 (17-05-2012)
  • HAL Id : hal-00698832 , version 1
David Selosse, Jérémie Dequidt, Laurent Grisoni. A Sketch-Based Interface for Annotation of 3D Brain Vascular Reconstructions. [Research Report] RR-7954, INRIA. 2012, pp.19. ⟨hal-00698832⟩
361 Consultations
143 Téléchargements
