The decoding Library for List Decoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The decoding library is a C library whose main goal is to implement as effi- ciently as possible the Guruswami-Sudan algorithm. It is written in C89 and is stand-alone.
abstract.pdf (100.48 Ko) Télécharger le fichier
hal-00700397 , version 1 (22-05-2012)
hal-00700397 , version 2 (06-06-2012)
Guillaume Quintin. The decoding Library for List Decoding. International Symposium on Symbolic and Algebraic Computation, Jul 2012, Grenoble, France. pp.168-170, ⟨10.1145/2429135.2429174⟩. ⟨hal-00700397v2⟩
158 Consultations
331 Téléchargements
