Accurate fitting of measured reflectances using a Shifted Gamma micro-facet distribution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2012
Material models are essential to the production of photo-realistic images. Measured BRDFs provide accurate representation with complex visual appearance, but have larger storage cost. Analytical BRDFs such as Cook- Torrance provide a compact representation but fail to represent the effects we observe with measured appearance. Accurately fitting an analytical BRDF to measured data remains a challenging problem. In this paper we introduce the SGD micro-facet distribution for Cook-Torrance BRDF. This distribution accurately models the behavior of most materials. As a consequence, we accurately represent all measured BRDFs using a single lobe. Our fitting procedure is stable and robust, and does not require manual tweaking of the parameters.
paper.pdf (1.71 Mo) Télécharger le fichier
SGD_Params.csv (35.98 Ko) Télécharger le fichier
materials.frag (1.9 Ko) Télécharger le fichier
materials.vert (669 B) Télécharger le fichier
plugin-EGSR2012.pdf (4.94 Mo) Télécharger le fichier
supplemental.pdf (68.13 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
hal-00702304 , version 1 (01-06-2012)
Mahdi M. Bagher, Cyril Soler, Nicolas Holzschuch. Accurate fitting of measured reflectances using a Shifted Gamma micro-facet distribution. Computer Graphics Forum, 2012, 31 (4), pp.1509-1518. ⟨10.1111/j.1467-8659.2012.03147.x⟩. ⟨hal-00702304⟩
3690 Consultations
5759 Téléchargements
