Reasoning with Triggers
SMT solvers can decide the satisfiability of ground formulas modulo a combination of built-in theories. Adding a built-in theory to a given SMT solver is a complex and time consuming task that requires internal knowledge of the solver. However, many theories can be easily expressed using first-order formulas. Unfortunately, since universal quantifiers are not handled in a complete way by SMT solvers, these axiomatics cannot be used as decision procedures. In this paper, we show how to extend a generic SMT solver to accept a custom theory description and behave as a decision procedure for that theory, provided that the described theory is complete and terminating in a precise sense. The description language consists of first-order axioms with triggers, an instantiation mechanism that is found in many SMT solvers. This mechanism, which usually lacks a clear semantics in existing languages and tools, is rigorously defined here; this definition can be used to prove completeness and termination of the theory. We demonstrate on two examples, how such proofs can be achieved in our formalism.
Informatique et langage [cs.CL]
