Real-time detection of overlapping sound events with non-negative matrix factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
In this paper, we investigate the problem of real-time detection of overlapping sound events by employing non-negative matrix factorization techniques. We consider a setup where audio streams arrive in real-time to the system and are decomposed onto a dictionary of event templates learned off-line prior to the decomposition. An important drawback of existing approaches in this context is the lack of controls on the decomposition. We propose and compare two provably convergent algorithms that address this issue, by controlling respectively the sparsity of the decomposition and the trade-off of the decomposition between the different frequency components. Sparsity regularization is considered in the framework of convex quadratic programming, while frequency compromise is introduced by employing the beta-divergence as a cost function. The two algorithms are evaluated on the multi-source detection tasks of polyphonic music transcription, drum transcription and environmental sound recognition. The obtained results show how the proposed approaches can improve detection in such applications, while maintaining low computational costs that are suitable for real-time.
Dessein2012MIG.pdf (511.72 Ko) Télécharger le fichier
hal-00708805 , version 1 (15-06-2012)
Arnaud Dessein, Arshia Cont, Guillaume Lemaitre. Real-time detection of overlapping sound events with non-negative matrix factorization. Nielsen, Frank and Bhatia, Rajendra. Matrix Information Geometry, Springer, pp.341-371, 2013, 978-3-642-30232-9. ⟨10.1007/978-3-642-30232-9_14⟩. ⟨hal-00708805⟩
234 Consultations
695 Téléchargements
