Optimal encoding of triangular and quadrangular meshes with fixed topology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Extending a bijection recently introduced by Poulalhon and Schaeffer [Icalp 2003] for triangulations of the sphere we design an efficient algorithm for encoding (topological) triangulations and bipartite quadrangulations on an orientable surface of fixed topology τ (given by the genus g and number of boundaries b). To our knowledge, our encoding procedure is the first to be asymptotically optimal (in the information theory sense) with respect to two natural parameters, the number n of inner vertices and the number k of boundary vertices.
OptimalTriangleQuadMeshes_CCCG2010.pdf (155.09 Ko) Télécharger le fichier
hal-00709972 , version 1 (19-06-2012)
  • HAL Id : hal-00709972 , version 1
Luca Castelli Aleardi, Eric Fusy, Thomas Lewiner. Optimal encoding of triangular and quadrangular meshes with fixed topology. 22nd Annual Canadian Conference on Computational Geometry, Aug 2010, Winnipeg, Canada. ⟨hal-00709972⟩
112 Consultations
44 Téléchargements
