s'authentifier
version française rss feed
hal-00710225, version 1
A retrial system with two input streams and two orbit queues
Konstantin Avrachenkov (, http://www-sop.inria.fr/mistral/personnel/K.Avrachenkov/me.html) a1, Philippe Nain (, http://www-sop.inria.fr/maestro/personnel/Philippe.Nain/) b1, Uri Yechiali () c2
N° RR-7999 (2012)
Résumé : Two independent Poisson streams of jobs flow into a single-server service system having a limited common buffer that can hold at most one job. If a type-i job (i=1,2) finds the server busy, it is blocked and routed to a separate type-i retrial (orbit) queue that attempts to re-dispatch its jobs at its specific Poisson rate. This creates a system with three dependent queues. Such a queueing system serves as a model for two competing job streams in a carrier sensing multiple access system. We study the queueing system using multi-dimensional probability generating functions, and derive its necessary and sufficient stability conditions while solving a boundary value problem. Various performance measures are calculated and numerical results are presented.
  • Collaboration : Tel Aviv University
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : Retrial queues – Riemann-Hilbert boundary value problem – Carrier sensing multiple access system
  • Référence interne : RR-7999
  • hal-00710225, version 1
  • oai:hal.inria.fr:hal-00710225
  • Contributeur :
  • Soumis le : Mercredi 20 Juin 2012, 12:35:53
  • Dernière modification le : Vendredi 22 Juin 2012, 08:36:32
tous les articles de la base du CCSd...
