hal-00710290, version 3
A New Bound on the Minimum Distance of Cyclic Codes Using Small-Minimum-Distance Cyclic Codes
Alexander Zeh
1, 2Sergey Bezzateev
3
Designs, Codes and Cryptography (2012)
Résumé : A new bound on the minimum distance of q-ary cyclic codes is proposed. It is based on the description by another cyclic code with small minimum distance. The connection to the BCH bound and the Hartmann--Tzeng (HT) bound is formulated explicitly. We show that for many cases our approach improves the HT bound. Furthermore, we refine our bound for several families of cyclic codes. We define syndromes and formulate a Key Equation that allows an efficient decoding up to our bound with the Extended Euclidean Algorithm. It turns out that lowest-code-rate cyclic codes with small minimum distances are useful for our approach. Therefore, we give a sufficient condition for binary cyclic codes of arbitrary length to have minimum distance two or three and lowest code-rate
- 1 : TANC (INRIA Saclay - Ile de France)
- INRIA – Polytechnique - X – CNRS : UMR7161
- 2 : Institute of Communications Engineering [Ulm] (INT - University of Ulm.)
- University of Ulm
- 3 : Saint Petersburg University of Aerospace Instrumentation (SUAI)
- Saint Petersburg University of Aerospace Instrumentation
- Domaine : Informatique/Théorie de l'information et codage
Mathématiques/Théorie de l'information et codage - Mots-clés : BCH Bound – Bound on the Minimum Distance – Cyclic Code – Decoding – Hartmann--Tzeng Bound
- Versions disponibles : v1 (21-06-2012) v2 (11-07-2012) v3 (31-08-2012)
- hal-00710290, version 3
- http://hal.inria.fr/hal-00710290
- oai:hal.inria.fr:hal-00710290
- Contributeur : Alexander Zeh
- Soumis le : Mercredi 29 Août 2012, 11:26:14
- Dernière modification le : Lundi 3 Septembre 2012, 19:21:27
Documents associés
Exporter
