Towards a certified computation of homology groups for digital images
In this paper we report on a project to obtain a verified computation of homology groups of digital images. The methodology is based on program- ming and executing inside the COQ proof assistant. Though more research is needed to integrate and make efficient more processing tools, we present some examples partially computed in COQ from real biomedical images.
Traitement des images [eess.IV]
