Subject and counter-subject detection for analysis of the Well-Tempered Clavier fugues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fugue analysis is a challenging problem. We propose an algorithm that detects subjects and counter-subjects in a symbolic score where all the voices are separated, determining the precise ends and the occurrence positions of these patterns. The algorithm is based on a diatonic similarity between pitch intervals combined with a strict length matching for all notes, except for the first and the last one. On the 24 fugues of the first book of Bach's Well-Tempered Clavier, the algorithm predicts 66% of the subjects with a musically relevant end, and finally retrieves 85% of the subject occurrences, with almost no false positive.
fugues-cmmr-2012-ggl.pdf (571.64 Ko) Télécharger le fichier
hal-00712554 , version 1 (27-06-2012)
  • HAL Id : hal-00712554 , version 1
Mathieu Giraud, Richard Groult, Florence Levé. Subject and counter-subject detection for analysis of the Well-Tempered Clavier fugues. International Symposium on Computer Music Modelling and Retrieval (CMMR 2012), 2012, United Kingdom. pp.661-673. ⟨hal-00712554⟩
436 Consultations
1377 Téléchargements
