GNSS pseudorange error density tracking using Dirichlet Process Mixture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In satellite navigation system, classical localization algorithms assume that the observation noise is white-Gaussian. This assumption is not correct when the signal is reflected on the surrounding obstacles. That leads to a decrease of accuracy and of continuity of service. To enhance the localization performances, a better observation noise density can be use in an adapted filtering process. This article aims to show how the Dirich-let Process Mixture can be employed to track the observation density on-line. This sequential estimation solution is adapted when the noise is non-stationary. The approach will be tested under a simulation scenario with multiple propagation conditions. Then, this density modeling will be used in Rao-Blackwellised Particle Filter.
Fichier non déposé
hal-00713046 , version 1 (28-06-2012)
  • HAL Id : hal-00713046 , version 1
Nicolas Viandier, Asma Rabaoui, Juliette Marais, Emmanuel Duflos. GNSS pseudorange error density tracking using Dirichlet Process Mixture. FUSION 2010, Jul 2010, Edinburgh, United Kingdom. pp.1-7. ⟨hal-00713046⟩
201 Consultations
0 Téléchargements
