Mathematical properties of a semi-classical signal analysis method: noisy signal case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Da-Yan Liu
Recently, a new signal analysis method based on a semi-classical approach has been proposed [1]. The main idea in this method is to interpret a signal as a potential of a Schrodinger operator and then to use the discrete spectrum of this operator to analyze the signal. In this paper, we are interested in a mathematical analysis of this method in discrete case considering noisy signals.
Error_analysis_for_scsa_final.pdf (153.54 Ko) Télécharger le fichier
hal-00713408 , version 1 (01-07-2012)
hal-00713408 , version 2 (29-08-2012)
Da-Yan Liu, Taous-Meriem Laleg-Kirati. Mathematical properties of a semi-classical signal analysis method: noisy signal case. 1st International Conference on Systems and Computer Science, Aug 2012, Villeneuve d'ascq, France. ⟨hal-00713408v2⟩
Collections
TDS-MACS
100 Consultations
109 Téléchargements
