Growing Least Squares for the Analysis of Manifolds in Scale-Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2012
We present a novel approach to the multi-scale analysis of point-sampled manifolds of co-dimension 1. It is based on a variant of Moving Least Squares, whereby the evolution of a geometric descriptor at increasing scales is used to locate pertinent locations in scale-space, hence the name "Growing Least Squares". Compared to existing scale-space analysis methods, our approach is the first to provide a continuous solution in space and scale dimensions, without requiring any parametrization, connectivity or uniform sampling. An important implication is that we identify multiple pertinent scales for any point on a manifold, a property that had not yet been demonstrated in the literature. In practice, our approach exhibits an improved robustness to change of input, and is easily implemented in a parallel fashion on the GPU. We compare our method to state-of-the-art scale-space analysis techniques and illustrate its practical relevance in a few application scenarios.
2012_GLS.pdf (10.14 Mo) Télécharger le fichier
hal-00713678 , version 1 (18-07-2012)
hal-00713678 , version 2 (24-02-2015)
Nicolas Mellado, Gaël Guennebaud, Pascal Barla, Patrick Reuter, Christophe Schlick. Growing Least Squares for the Analysis of Manifolds in Scale-Space. Computer Graphics Forum, 2012, Proceedings of Symposium on Geometry Processing 2012, 31 (5), pp.1691-1701. ⟨10.1111/j.1467-8659.2012.03174.x⟩. ⟨hal-00713678v2⟩
746 Consultations
1471 Téléchargements
