A framework for supporting views in Component Oriented Information Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The Component Oriented Design of Information Systems is spreading. After being used for gaining in reusability at the architectural level, components are nowadays applied at the business logic level. We focus here on the design of multiple functional views in such information systems, specially within the EJB framework. Traditionally, in the database context, this problem is solved by the notion of view-schemas applied to a database schema. We present a composition-oriented approach grounded on the splitting of entities according to views requirements. Two original design patterns are formulated and capture the main issues of the approach. The first one is concerned with the management of the split component and its conceptual identity. The second offers a solution for relationships among such components. Finally, we apply these patterns to the EJB framework. This framework improves evolution and traceability of views.
hal-00714267 , version 1 (03-07-2012)
Olivier Caron, Bernard Carré, Alexis Muller, Gilles Vanwormhoudt. A framework for supporting views in Component Oriented Information Systems. Object-Oriented Information Systems, 9th International Conference, OOIS 2003, 2003, Genève, Switzerland. pp.164-178, ⟨10.1007/978-3-540-45242-3_16⟩. ⟨hal-00714267⟩
126 Consultations
0 Téléchargements
