Singular factors of rational plane curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2012
We give a complete factorization of the invariant factors of resultant matrices built from birational parameterizations of rational plane curves in terms of the singular points of the curve and their multiplicity graph. This allows us to prove the validity of some conjectures about these invariants stated by Chen, Wang and Liu. As a byproduct, we also give a complete factorization of the D-resultant for rational functions in terms of the similar data extracted from the multiplicities.
SingularFactor_final.pdf (437.37 Ko) Télécharger le fichier
hal-00714544 , version 1 (04-07-2012)
  • HAL Id : hal-00714544 , version 1
Laurent Busé, Carlos d'Andrea. Singular factors of rational plane curves. Journal of Algebra, 2012, 357, pp.322-346. ⟨hal-00714544⟩
185 Consultations
192 Téléchargements
