An Eclipse Modelling Framework Alternative to Meet the Models@Runtime Requirements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Models@Runtime aims at taming the complexity of software dynamic adaptation by pushing further the idea of reflection and con- sidering the reflection layer as a first-class modeling space. A natural approach to Models@Runtime is to use MDE techniques, in particular those based on the Eclipse Modeling Framework. EMF provides facilities for building DSLs and tools based on a structured data model, with tight integration with the Eclipse IDE. EMF has rapidly become the defacto standard in the MDE community and has also been adopted for building Models@Runtime platforms. For example, Frascati (implementing the Service Component Architecture standard) uses EMF for the design and runtime tooling of its architecture description language. However, EMF has primarily been thought to support design-time activities. This paper highlights specific Models@Runtime requirements, discusses the bene- fits and limitations of EMF in this context, and presents an alternative implementation to meet these requirements.
emfatruntime.pdf (359 Ko) Télécharger le fichier
hal-00714558 , version 1 (05-07-2012)
  • HAL Id : hal-00714558 , version 1
François Fouquet, Grégory Nain, Brice Morin, Erwan Daubert, Olivier Barais, et al.. An Eclipse Modelling Framework Alternative to Meet the Models@Runtime Requirements. Models 2012, Oct 2012, Innsbruck, Austria. ⟨hal-00714558⟩
490 Consultations
1650 Téléchargements
