DiaSim: A Simulator for Pervasive Computing Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software: Practice and Experience Année : 2013
Pervasive computing applications involve both software concerns, like any software system, and integration concerns, for the constituent networked devices of the pervasive computing environment. This situation is problematic for testing because it requires acquiring, testing and interfacing a variety of software and hardware entities. This process can rapidly become costly and time-consuming when the target environment involves many entities. This paper introduces DiaSim, a simulator for pervasive computing applications. To cope with widely heterogeneous entities, DiaSim is parameterized with respect to a description of a target pervasive computing environment. This description is used to generate both a programming framework to develop the simulation logic and an emulation layer to execute applications. Furthermore, a simulation renderer is coupled to DiaSim to allow a simulated pervasive system to be visually monitored and debugged. DiaSim has been implemented and used to simulate various pervasive computing systems in different application areas, demonstrating the generality of our parameterized approach.
simulation.pdf (738.29 Ko) Télécharger le fichier
hal-00715745 , version 1 (18-07-2012)
Julien Bruneau, Charles Consel. DiaSim: A Simulator for Pervasive Computing Applications. Software: Practice and Experience, 2013, 43 (8), ⟨10.1002/spe.2130⟩. ⟨hal-00715745⟩
Collections
CNRS INRIA INRIA2
333 Consultations
708 Téléchargements
