A new feature and associated optimal spatial filter for EEG signal classification: Waveform Length - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce Waveform Length (WL), a new feature for ElectroEncephaloGraphy (EEG) signal classification which measures the signal complexity. We also propose the Waveformlength Optimal Spatial Filter (WOSF), an optimal spatial filter to classify EEG signals based on WL features. Evaluations on 15 subjects suggested that WOSF with WL features provide performances that are competitive with that of Common Spatial Patterns (CSP) with Band Power (BP) features, CSP being the optimal spatial filter for BP features. More interestingly, our results suggested that combining WOSF with CSP features leads to classification performances that are significantly better than that of CSP alone (80% versus 77% average accuracy respectively).
lotte12.pdf (142.31 Ko) Télécharger le fichier
hal-00717617 , version 1 (13-07-2012)
  • HAL Id : hal-00717617 , version 1
Fabien Lotte. A new feature and associated optimal spatial filter for EEG signal classification: Waveform Length. International Conference on Pattern Recognition (ICPR), Nov 2012, Tsukuba, Japan. ⟨hal-00717617⟩
Collections
CNRS INRIA INRIA2
156 Consultations
989 Téléchargements
