Deriving Configuration Interfaces from Feature Models: A Vision Paper - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In software product lines, feature models are the de-facto standard for representing variability as well as for configuring products. Yet, configuration relying on feature models faces two issues: i) it assumes knowledge of the underlying formalism, which may not be true for end users and ii) it does not take advantage of advanced user-interface controls, leading to usability and integration problems with other parts of the user interface. To address these issues, our research focuses on the generation of configuration interfaces based on variability models, both from the visual and behavioral perspectives. We tackle visual issues by generating abstract user-interfaces from feature models. Regarding configuration behavior, in particular the configuration sequence, we plan to use feature configuration workflows, variability-aware models that exhibit similar characteristics as of task, user, discourse and business models found in the in the human-computer interaction community. This paper discusses the main challenges and possible solutions to realize our vision.
Fichier non déposé
hal-00718286 , version 1 (16-07-2012)
Quentin Boucher, Gilles Perrouin, Patrick Heymans. Deriving Configuration Interfaces from Feature Models: A Vision Paper. Sixth International Workshop on Variability Modelling of Software-Intensive Systems, Jan 2012, Leipzig, Germany. pp.37-44, ⟨10.1145/2110147.2110152⟩. ⟨hal-00718286⟩
116 Consultations
0 Téléchargements
