Automatic Service Categorisation through Machine Learning in Emergent Middleware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The modern environment of mobile, pervasive, evolving ser- vices presents a great challenge to traditional solutions for enabling in- teroperability. Automated solutions appear to be the only way to achieve interoperability with the needed level of flexibility and scalability. While necessary, the techniques used to determine compatibility, as a precursor to interaction, come at a substantial computational cost, especially when checks are performed between systems in unrelated domains. To over- come this, we apply machine learning to extract high-level functionality information through text categorisation of a system's interface descrip- tion. This categorisation allows us to restrict the scope of compatibility checks, giving an overall performance gain when conducting matchmak- ing between systems. We have evaluated our approach on a corpus of web service descriptions, where even with moderate categorisation accuracy, a substantial performance benefit can be found. This in turn improves the applicability of our overall approach for achieving interoperability in the Connect project.
FMCO.PDF (653.24 Ko) Télécharger le fichier
hal-00718655 , version 1 (17-07-2012)
Amel Bennaceur, Valérie Issarny, Johansson Richard, Moschitti Alessandro, Spalazzese Romina, et al.. Automatic Service Categorisation through Machine Learning in Emergent Middleware. FMCO 2011 - 10th International Symposium on Formal Methods for Components and Objects, Oct 2011, Turin, Italy. pp.133-149, ⟨10.1007/978-3-642-35887-6_7⟩. ⟨hal-00718655⟩
222 Consultations
218 Téléchargements
