Exactly Solvable Balanced Tenable Urns with Random Entries via the Analytic Methodology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
This paper develops an analytic theory for the study of some Pólya urns with random rules. The idea is to extend the isomorphism theorem in Flajolet et al. (2006), which connects deterministic balanced urns to a differential system for the generating function. The methodology is based upon adaptation of operators and use of a weighted probability generating function. Systems of differential equations are developed, and when they can be solved, they lead to characterization of the exact distributions underlying the urn evolution. We give a few illustrative examples.
dmtcs_mahmoud_morcrette_aofa12.pdf (367.14 Ko) Télécharger le fichier
hal-00719639 , version 1 (20-07-2012)
Paternité
Basile Morcrette, Hosam M. Mahmoud. Exactly Solvable Balanced Tenable Urns with Random Entries via the Analytic Methodology. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), Jun 2012, Montreal, Canada. pp.219--232, ⟨10.46298/dmtcs.2996⟩. ⟨hal-00719639⟩
477 Consultations
511 Téléchargements
