Interval State Observer for Nonlinear Time Varying Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2013
This paper is devoted to design of interval observers for Linear Time Varying (LTV) systems and a class of nonlinear time-varying systems in the output canonical form. An interval observer design is feasible if it is possible to calculate the observer gains making the estimation error dynamics cooperative and stable. It is shown that under some mild conditions the cooperativity of an LTV system can be ensured by a static linear transformation of coordinates. The efficiency of the proposed approach is demonstrated through numerical simulations.
Automatique
Interval_LTV_J.pdf (231.37 Ko) Télécharger le fichier
hal-00719911 , version 1 (22-07-2012)
Denis Efimov, Tarek Raissi, Stanislav Chebotarev, Ali Zolghadri. Interval State Observer for Nonlinear Time Varying Systems. Automatica, 2013, 49 (1), pp.200--205. ⟨10.1016/j.automatica.2012.07.004⟩. ⟨hal-00719911⟩
381 Consultations
1294 Téléchargements
