On the uniqueness of a quadratic programming-based solution to linear regression estimation from quantized measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Jiandong Wang
  • Fonction : Auteur
  • PersonId : 928110
As a complement to a recently proposed quadratic programming (QP)-based method for linear regression estimation from quantized or binary data, this report presents a complete input condition ensuring the uniqueness of result of the QP-based method.
Automatique
completeInputWeb.pdf (102.34 Ko) Télécharger le fichier
hal-00720150 , version 1 (23-07-2012)
  • HAL Id : hal-00720150 , version 1
Qinghua Zhang, Jiandong Wang. On the uniqueness of a quadratic programming-based solution to linear regression estimation from quantized measurements. [Research Report] 2012, pp.12. ⟨hal-00720150⟩
Collections
INRIA INRIA2 LARA
81 Consultations
76 Téléchargements
