Themis: A Spot-Market Based Automatic Resource Scaling Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cloud computing brings new provisioning models that offer applications more flexibility and better control over their resource allocations. However these models suffer from the following problem: either they provide limited support for applications demanding quality of service, or they lead to a limited infrastructure utilization. In this paper we propose Themis, a novel resource management system for virtualized infrastructures based on a virtual economy. By limiting the coupling between the applications and the infrastructure through the use of a dynamic resource pricing mechanism, Themis can support diverse types of applications and performance goals while ensuring an efficient resource usage.
poster.pdf (225.95 Ko) Télécharger le fichier
hal-00721695 , version 1 (30-07-2012)
  • HAL Id : hal-00721695 , version 1
Stefania Victoria Costache, Nikos Parlavantzas, Christine Morin, Samuel Kortas. Themis: A Spot-Market Based Automatic Resource Scaling Framework. HPDC 2012 Poster Session, Jun 2012, Delft, Netherlands. ⟨hal-00721695⟩
450 Consultations
142 Téléchargements
