s'authentifier
version française rss feed
hal-00722397, version 1
Optimization driven multi-hop network design and experimentation: the approach of the FP7 project OPNEX
Kostas Choumas 1, Stratos Keranidis 1, Thanasis Korakis 1, Iordanis Koutsopoulos 12, Leandros Tassiulas 12, Felix Juraschek 3, Mesut Günes 3, Emmanuel Baccelli 4, Paweł Misiorek 5, Andrzej Szwabe 5, Theodoros Salonidis 6, Henrik Lundgren 6
IEEE Communications Magazine 50 (2012) 122 - 130
Résumé : The OPNEX project exemplifies system and optimization theory as the foundations for algorithms that provably maximize capacity of wireless networks. The algorithms termed in abstract network models have been converted to protocols and architectures practically applicable to wireless systems. A validation methodology through experimental protocol evaluation in real network testbeds has been proposed and used. OPNEX uses recent advances in system theoretic network control, including the Back-Pressure principle, max-weight scheduling, utility optimization, congestion control, and the primal-dual method for extracting network algorithms. These approaches exhibited vast potential for achieving high capacity and full exploitation of resources in abstract network models and found their way to reality in high performance architectures developed as a result of the research conducted within OPNEX.
  • Domaine : Informatique/Réseaux et télécommunications
  • hal-00722397, version 1
  • oai:hal.archives-ouvertes.fr:hal-00722397
  • Contributeur :
  • Soumis le : Mercredi 1 Août 2012, 15:27:16
  • Dernière modification le : Mercredi 1 Août 2012, 16:28:15
tous les articles de la base du CCSd...
