Local Higher-Order Statistics (LHS) for Texture Categorization and Facial Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a new image representation for texture categorization and facial analysis, relying on the use of higher-order local di fferential statistics as features. In contrast with models based on the global structure of textures and faces, it has been shown recently that small local pixel pattern distributions can be highly discriminative. Motivated by such works, the proposed model employs higher-order statistics of local non-binarized pixel patterns for the image description. Hence, in addition to being remarkably simple, it requires neither any user specfi ed quantization of the space (of pixel patterns) nor any heuristics for discarding low occupancy volumes of the space. This leads to a more expressive representation which, when combined with discriminative SVM classi er, consistently achieves state-of-the-art performance on challenging texture and facial analysis datasets outperforming contemporary methods (with similar powerful classi ers).
lhs_eccv12.pdf (396.47 Ko) Télécharger le fichier
hal-00722819 , version 1 (04-08-2012)
Gaurav Sharma, Sibt Ul Hussain, Frédéric Jurie. Local Higher-Order Statistics (LHS) for Texture Categorization and Facial Analysis. ECCV 2012 - European Conference on Computer Vision, Oct 2012, Florence, Italy. pp.1-12, ⟨10.1007/978-3-642-33786-4_1⟩. ⟨hal-00722819⟩
506 Consultations
910 Téléchargements
