s'authentifier
version française rss feed
hal-00723691, version 3
A surface-based electrophysiology model relying on asymptotic analysis and motivated by cardiac atria modeling
Dominique Chapelle (Auteur à contacter de préférence) 1, Annabelle Collin () 1, Jean-Frédéric Gerbeau () 2
Mathematical Models and Methods in Applied Sciences (2013)
Résumé : Computational electrophysiology is a very active field with tremendous potential in medical applications, albeit leads to highly intensive simulations. We here propose a surface-based electrophysiology formulation, motivated by the modeling of thin structures such as cardiac atria, which greatly reduces the size of the computational models. Moreover, our model is specifically devised to retain the key features associated with the anisotropy in the diffusion effects induced by the fiber architecture, with rapid variations across the thickness which cannot be adequately represented by naive averaging strategies. Our proposed model relies on a detailed asymptotic analysis in which we identify a limit model and establish strong convergence results. We also provide detailed numerical assessments which confirm an excellent accuracy of the surface-based model -- compared with the reference 3D model -- including in the representation of a complex phenomenon, namely, spiral waves.
  • Domaine : Mathématiques/Analyse numérique
  • Mots-clés : Computational electrophysiology – Asymptotic analysis – Thin domains – Cardiac modeling
  • Versions disponibles :  v1 (13-08-2012) v2 (20-02-2013) v3 (24-04-2013)
  • hal-00723691, version 3
  • oai:hal.inria.fr:hal-00723691
  • Contributeur :
  • Soumis le : Mercredi 24 Avril 2013, 10:17:25
  • Dernière modification le : Mercredi 24 Avril 2013, 11:14:26
tous les articles de la base du CCSd...
