Convex dwell-time characterizations for uncertain linear impulsive systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2012
Corentin Briat
Alexandre Seuret
New sufficient conditions for the characterization of dwell-times for linear impulsive systems are proposed and shown to coincide with continuous decrease conditions of a certain class of looped-functionals, a recently introduced type of functionals suitable for the analysis of hybrid systems. This approach allows to consider Lyapunov functions that evolve non-monotonically along the flow of the system in a new way, broadening then the admissible class of systems which may be analyzed. As a byproduct, the particular structure of the obtained conditions makes the method is easily extendable to uncertain systems by exploiting some convexity properties. Several examples illustrate the approach.
hal-00724546 , version 1 (21-08-2012)
Corentin Briat, Alexandre Seuret. Convex dwell-time characterizations for uncertain linear impulsive systems. IEEE Transactions on Automatic Control, 2012, 57 (12), pp.3241-3246. ⟨10.1109/TAC.2012.2200379⟩. ⟨hal-00724546⟩
279 Consultations
0 Téléchargements
