1d WCIP and FEM hybridization
An hybridization between two numerical methods, the 1d Wave Concept Iterative Procedure (WCIP) and the 2d Finite Element Method (FEM), is developed. Using two examples, comparisons are provided between the new hybrid method and an analytic solution, when available, or the WCIP alone.
Origine : Accord explicite pour ce dépôt
