Topology driven 3D mesh hierarchical segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Julien Tierny
Mohamed Daoudi
In this paper, we propose to address the semantic- oriented 3D mesh hierarchical segmentation problem, using enhanced topological skeletons. This high level information drives both the feature boundary computation as well as the feature hierarchy definition. Proposed hierarchical scheme is based on the key idea that the topology of a feature is a more important decomposition criterion than its geometry. First, the enhanced topological skeleton of the input triangulated surface is constructed. Then it is used to delimit the core of the object and to identify junction areas. This second step results in a fine segmentation of the object. Finally, a fine to coarse strategy enables a semantic-oriented hierarchical composition of features, subdividing human limbs into arms and hands for example. Method performance is evaluated according to seven criteria enumerated in latest segmentation surveys. Thanks to the high level description it uses as an input, presented approach results, with low computation times, in robust and meaningful compatible hierarchical decompositions.
smi2007-segmentation.pdf (412.99 Ko) Télécharger le fichier
hal-00725321 , version 1 (24-08-2012)
  • HAL Id : hal-00725321 , version 1
Julien Tierny, Jean-Philippe Vandeborre, Mohamed Daoudi. Topology driven 3D mesh hierarchical segmentation. IEEE International Conference on Shape Modeling and Applications (Shape Modeling International - SMI), Jun 2007, Lyon, France. pp.SP. ⟨hal-00725321⟩
218 Consultations
270 Téléchargements
