Reduced-basis solutions of affinely-parametrized linear partial differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
This document presents the reduced basis method for the fast many-query computation of solutions of affinely-parametrized elliptic linear partial differential equations.
RappRB.pdf (181.75 Ko) Télécharger le fichier
hal-00725344 , version 1 (24-08-2012)
  • HAL Id : hal-00725344 , version 1
Alexandre Janon. Reduced-basis solutions of affinely-parametrized linear partial differential equations. [Research Report] LJK. 2010. ⟨hal-00725344⟩
197 Consultations
317 Téléchargements
