Models of Tet-On System with Epigenetic Effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Computer Science Année : 2012
We present the first results of ongoing work investigating two models of the artificial inducible promoter Tet-On that include epigenetic regulation. We consider chromatin states and 1D diffusion of transcription factors that reveal, respectively, stochastic noise and a memory effect.
0.pdf (308.45 Ko) Télécharger le fichier
hal-00725553 , version 1 (27-08-2012)
  • HAL Id : hal-00725553 , version 1
Russ Harmer, Jean Krivine, Élise Laruelle, Cédric Lhoussaine, Guillaume Madelaine, et al.. Models of Tet-On System with Epigenetic Effects. Computational Methods in Systems Biology 2012 (CMSB 2012, Flashposter), Oct 2012, London, United Kingdom. pp.378. ⟨hal-00725553⟩
199 Consultations
173 Téléchargements
