Multiscale skewed heavy tailed model for texture analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper deals with texture analysis based on multiscale stochastic modeling. In contrast to common approaches using symmetric marginal probability density functions of subband coefficients, experimental manipulations show that the symmetric shape assumption is violated for several texture classes. From this fact, we propose in this paper to exploit this shape property to improve texture characterization. We present Asymmetric Generalized Gaussian density as a model to represent detail subbands resulting from multiscale decomposition. A fast estimation method is presented and closed-form of Kullback-Leibler divergence is provided in order to validate the model into a retrieval scheme. The experimental results indicate that this model achieves higher recognition rates than the conventional approach of using the Generalized Gaussian model where asymmetry was not considered.
icip2009_NL_-_Corr.pdf (600.9 Ko) Télécharger le fichier
hal-00727111 , version 1 (03-09-2012)
Nour-Eddine Lasmar, Youssef Stitou, Yannick Berthoumieu. Multiscale skewed heavy tailed model for texture analysis. ICIP - IEEE International Conference on Image Processing, 2009, Cairo, Egypt. pp.2281-2284, ⟨10.1109/ICIP.2009.5414404⟩. ⟨hal-00727111⟩
194 Consultations
1459 Téléchargements
