TRASA: TRaffic Aware Slot Assignment Algorithm in Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ichrak Amdouni
  • Fonction : Auteur
  • PersonId : 898418
Pascale Minet
In data gathering applications which is a typical application paradigm in wireless sensor networks, sensor nodes may have different traffic demands. Assigning equal channel access to each node may lead to congestion, inefficient use of the bandwidth and decrease of the application performance. In this paper, we prove that the time slot assignment problem is NP-complete when p-hop nodes are not assigned the same slot, with 1 <= p <= h for any strictly positive integer h. We propose TRASA, a TRaffic Aware time Slot Assignment algorithm able to allocate slots to sensors proportionally to their demand. We evaluate the performance of TRASA for different heuristics and prove that it provides an optimized spatial reuse and a minimized cycle length.
paper.pdf (271.81 Ko) Télécharger le fichier
hal-00728871 , version 1 (07-09-2012)
Ichrak Amdouni, Pascale Minet. TRASA: TRaffic Aware Slot Assignment Algorithm in Wireless Sensor Networks. ICCIT 2012 – Second International Conference on Communications and Information Technology, Jun 2012, Hammamet, Tunisia. ⟨hal-00728871⟩
124 Consultations
116 Téléchargements
